Ga door naar hoofdinhoud
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
Wat je nodig hebt
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: stap 1, afbeelding 1 van 2 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: stap 1, afbeelding 2 van 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: stap 2, afbeelding 1 van 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): stap 3, afbeelding 1 van 1
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: stap 4, afbeelding 1 van 1
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: stap 5, afbeelding 1 van 1
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Conclusie
Matthew Selting
432 Reputatie
4 handleidingen geschreven
UW Stout, Team S8-G4, Ogden Spring 2018 Lid van UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 157
