Ga door naar hoofdinhoud
Protocol Galileo Stealth Housing Replacement
Wat je nodig hebt
  1. Protocol Galileo Stealth Housing Replacement, Propeller: stap 1, afbeelding 1 van 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: stap 3, afbeelding 1 van 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: stap 4, afbeelding 1 van 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: stap 5, afbeelding 1 van 2 Protocol Galileo Stealth Housing Replacement, Housing: stap 5, afbeelding 2 van 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: stap 6, afbeelding 1 van 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Conclusie
Matthew Selting
432 Reputatie
4 handleidingen geschreven
UW Stout, Team S8-G4, Ogden Spring 2018 Lid van UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 146
