Ga door naar hoofdinhoud
Protocol Galileo Stealth Battery Replacement
  1. Protocol Galileo Stealth Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the door to the battery compartment on the underside of the drone.
  2. Protocol Galileo Stealth Battery Replacement: stap 2, afbeelding 1 van 1
    • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
  3. Protocol Galileo Stealth Battery Replacement: stap 3, afbeelding 1 van 1
    • First pull out the wires located to the side of the battery.
    • Carefully remove the battery from the battery compartment
    • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
    • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
  4. Protocol Galileo Stealth Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the two ends of the wires by lightly pulling them apart.
Conclusie
stephen R masalewicz
270 Reputatie
2 handleidingen geschreven
UW Stout, Team S8-G4, Ogden Spring 2018 Lid van UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Leden
6 handleidingen geschreven
Één opmerking
Please were can buy the battery
odoffin Kehinde - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 633
