Ga door naar hoofdinhoud
Protocol Dronium Two Rechargeable Battery Replacement
Wat je nodig hebt
  1. Protocol Dronium Two Rechargeable Battery Replacement, Rechargeable Battery: stap 1, afbeelding 1 van 1
    • Turn the drone off by moving the selector switch to the left.
  2. Protocol Dronium Two Rechargeable Battery Replacement: stap 2, afbeelding 1 van 1
    • On the underside of the drone, gently pull the battery compartment away from the drone.
    • Press down on the camera as shown to get a better grip.
  3. Protocol Dronium Two Rechargeable Battery Replacement: stap 3, afbeelding 1 van 2 Protocol Dronium Two Rechargeable Battery Replacement: stap 3, afbeelding 2 van 2
    • If the power cable of the battery is connected to the drone, remove it by gently pulling it out.
  4. Protocol Dronium Two Rechargeable Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from its compartment by sliding it out away from the drone.
Conclusie
Edwin Brietz
557 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 438
