Inleiding
This is how to remove and replace the HD camera on the underside of the drone if necessary. Be careful not to pull on the wires as that may damage them. Removing the landing gear closest to the camera wires will make this job easier. Please use a clean and well lit area, as the screws are small.
Wat je nodig hebt
Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
Één andere persoon heeft deze handleiding voltooid.
