Ga door naar hoofdinhoud
Protocol Dronium III AP Camera Replacement
Wat je nodig hebt
  1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: stap 1, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: stap 1, afbeelding 2 van 2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Camera Replacement: stap 3, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 3, afbeelding 2 van 2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Camera Replacement, Camera: stap 4, afbeelding 1 van 1
    • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
  5. Protocol Dronium III AP Camera Replacement: stap 5, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 5, afbeelding 2 van 2
    • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Camera Replacement: stap 6, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 6, afbeelding 2 van 2
    • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Camera Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the tape covering the camera with the tweezers.
  8. Protocol Dronium III AP Camera Replacement: stap 8, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 8, afbeelding 2 van 2
    • Remove the plastic holding the ribbon cable connector with the tweezers.
    • Be careful with the ribbon cable, it is easy to damage.
  9. Protocol Dronium III AP Camera Replacement: stap 9, afbeelding 1 van 1
    • Move the ribbon cable out of the way with the Spuger.
  10. Protocol Dronium III AP Camera Replacement: stap 10, afbeelding 1 van 2 Protocol Dronium III AP Camera Replacement: stap 10, afbeelding 2 van 2
    • Remove the camera by gently prying it out of the bracket with the spudger.
Conclusie
Steven Mooers
401 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G1, Rose Fall 2017 Lid van UW Tacoma, Team S1-G1, Rose Fall 2017
UWT-ROSE-F17S1G1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 371
