Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
With the help of the Wake Up Everyday feature, you can launch daily tasks at a fixed hour without having to be at home or work.
    • When starting your computer, press the DELETE (DEL) or F2 key according to your motherboard
  1. With the arrow keys, move the header towards the Alimentation tab.
    • With the arrow keys, move the header towards the Alimentation tab.
  2. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Once again with the arrow keys, higlight the APM Configuration option and press Enter.
    • Once again with the arrow keys, higlight the APM Configuration option and press Enter.
  4. Navigate to the Power On by RTC alarm and press Enter. Then, select the Enable option. The RTC Alarm Date option allows you to set the number of days for when your computer will be able to start on its own. Specify the desired hour for startup.
    • Navigate to the Power On by RTC alarm and press Enter. Then, select the Enable option.
    • The RTC Alarm Date option allows you to set the number of days for when your computer will be able to start on its own.
    • Specify the desired hour for startup.
    • Press the F10 key and confirm by pressing Enter when Yes is highlighted. Your pc will start automatically at the specified time and number of days that were previously specified.
Conclusie
If your BIOS does not have this function, software designed for this type of use is available and easy to set up.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Amrounassim
298 Reputatie
1 Handleiding geschreven
DongiTech Lid van DongiTech
Business
1 Lid
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 119
