Ga door naar hoofdinhoud
ProfiMixx 44 Disassembly
  1. ProfiMixx 44 Disassembly, Removing the scrapers: stap 1, afbeelding 1 van 3 ProfiMixx 44 Disassembly, Removing the scrapers: stap 1, afbeelding 2 van 3 ProfiMixx 44 Disassembly, Removing the scrapers: stap 1, afbeelding 3 van 3
    • Removing the five (TR15) scrapers
  2. ProfiMixx 44 Disassembly, Removing the housing: stap 2, afbeelding 1 van 2 ProfiMixx 44 Disassembly, Removing the housing: stap 2, afbeelding 2 van 2
    • Removing the first part of the housing
    • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
    • Removing the second part of the housing
  3. ProfiMixx 44 Disassembly, Assembly of the housing I: stap 3, afbeelding 1 van 3 ProfiMixx 44 Disassembly, Assembly of the housing I: stap 3, afbeelding 2 van 3 ProfiMixx 44 Disassembly, Assembly of the housing I: stap 3, afbeelding 3 van 3
    • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
    • Make sure that the two strands run as marked in blue.
    • The white element must be in the rear position. (marked in orange)
  4. ProfiMixx 44 Disassembly, Assembly of the housing II: stap 4, afbeelding 1 van 3 ProfiMixx 44 Disassembly, Assembly of the housing II: stap 4, afbeelding 2 van 3 ProfiMixx 44 Disassembly, Assembly of the housing II: stap 4, afbeelding 3 van 3
    • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
    • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
    • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
    • Then you can tighten the upper housing part with the five screws (TR15).
Eindstreep
Justus Klingler
531 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 61
Altijd: 1,508
