Ga door naar hoofdinhoud
Professional Series PS77401 Shell Removal
Wat je nodig hebt
  1. Professional Series PS77401 Shell Removal, Shell: stap 1, afbeelding 1 van 1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Shell Removal: stap 2, afbeelding 1 van 2 Professional Series PS77401 Shell Removal: stap 2, afbeelding 2 van 2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Shell Removal: stap 3, afbeelding 1 van 3 Professional Series PS77401 Shell Removal: stap 3, afbeelding 2 van 3 Professional Series PS77401 Shell Removal: stap 3, afbeelding 3 van 3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Shell Removal: stap 4, afbeelding 1 van 2 Professional Series PS77401 Shell Removal: stap 4, afbeelding 2 van 2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zachary
243 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-36, Maness Winter 2014 Lid van Cal Poly, Team 10-36, Maness Winter 2014
CPSU-MANESS-W14S10G36
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 743
