Ga door naar hoofdinhoud
Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
  1. Deze stap is niet vertaald. Help het te vertalen
    : stap 1, afbeelding 1 van 3 : stap 1, afbeelding 2 van 3 : stap 1, afbeelding 3 van 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
    No volume buttons and home button wont navigate
    Joy - Antwoord
  2. Deze stap is niet vertaald. Help het te vertalen
    : stap 2, afbeelding 1 van 2 : stap 2, afbeelding 2 van 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
Eindstreep
35 andere personen hebben deze handleiding voltooid.
ZFix
191.534 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.490 handleidingen geschreven
13 opmerkingen
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - Antwoord
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - Antwoord
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - Antwoord
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - Antwoord
This is a great post. Helped me easily navigate the recovery menu on my bricked phone.
fsmanchies - Antwoord
By contrast, i still like to using the recovery tool to restore lost files from Android phone ,it can scan some of deleted photos from my Android SD card,http://www.android-rescuer.com/recover-d...
Tamster - Antwoord
Yes it worked thank you
Jesse Brook - Antwoord
Thanks for sharing so many interesting technical articles. I have read most of them and gain lots knowledge. And I want to share some technical articles with your reader. And I also know a good tool do well in navigation in the Android phones, or you can just search on Google with FoneDog for more detail.
Agle - Antwoord
doesn’t work for me please help me!
Bruce LUI - Antwoord
That was exactly my problem !! And I followed your steps and it worked very well, thanks a lot
Safa Fituri - Antwoord
Mine still gets stuck on the T-Mobile boot screen.
AlwaysAStudent - Antwoord
J'ai oublié mot de passe tablette Samsung A7 à l'aide
Tulipe 64 Bouquet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 37
Altijd: 74,323
