Ga door naar hoofdinhoud
Problem with navigation in the Android System Recovery menu
Video overzicht
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: stap 1, afbeelding 1 van 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: stap 1, afbeelding 2 van 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: stap 1, afbeelding 3 van 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
  2. Problem with navigation in the Android System Recovery menu: stap 2, afbeelding 1 van 2 Problem with navigation in the Android System Recovery menu: stap 2, afbeelding 2 van 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
Conclusie
36 andere personen hebben deze handleiding voltooid.
ZFix
195.943 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
329 Leden
1.452 handleidingen geschreven
13Gids Commentaar
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - Antwoord
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - Antwoord
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - Antwoord
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 76
Altijd: 75,416
