Ga door naar hoofdinhoud
ProScan PLT7223G Battery Replacement
Wat je nodig hebt
  1. ProScan PLT7223G Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
    • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
    • Soldering tool will get hot, handle with care.
  4. ProScan PLT7223G Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to remove the black tape from the battery.
  5. ProScan PLT7223G Battery Replacement: stap 5, afbeelding 1 van 1
    • Using the flat end of a spudger, carefully separate the battery from the base of the device.
    • There is an adhesive holding the charger in place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
what is the number of the replacement battery??
florcomm - Antwoord
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 4,239
