Inleiding
Thermal fuses are the most common part in a toaster that stop working. When a toaster machine stops working, people usually throw it away and buy a new one. however, the problem is really simple to fix, and is way cheaper than buying a new Croque Monsieur-/panini press. We are going to show you how.
Wat je nodig hebt
Pull the plug of the panini press the out of the socket.
Unclip the black 'closing part' and open the toaster.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Don't solder the fuse to the cables because they are temperature-controlled fuses. When using a hot soldering iron, the fuse will break down again!
