Wat je nodig hebt
Detach the cover/serving bowl from the popper.
Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
Remove the two black wire twist caps, and unwind the different wires.
Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
Bijna klaar!
Conclusie
