Wat je nodig hebt
Remove the 2 bolts from the back cover and back cover should come off .
This is the recline cylinder . It is located on the lower left hand side of the chair from the front.
Remove cotter pin. Set this aside as this will be reused for reassembly.
Using a Small hammer LIGHTLY tap the bolt out of the cylinder mount point. Once its at the point shown in the photo you can use pliers or vice grips to pull it out.
This is the bolt for the Rear mount , notice how it is grooved on one side.
This is the bolt for Front mount.
These zip ties cannot be installed tightly as they are mounted to a moving cylinder . If they are over tightened it will damage the slide cylinder and wires. Keep the zip ties loose, but not too loose. Test the recline with all covers are off and watch these wires as the chair slides forward.
Remember this zip tie that holds the footrest data cables to the cylinder . This shouldn't have to be cut you can most likely slip it off of the cylinder. If not not cut and replace.
When installing the front cover be sure the top portion is done first . Additionally it needs to be behind the brackets marked here. SEE STEP 3
