Ga door naar hoofdinhoud
Presidential Footrest Disassembly
Wat je nodig hebt
  1. Presidential Footrest Disassembly, Step 1: stap 1, afbeelding 1 van 1
    • Be sure footrest is on a surface that wont scratch the bottom.
    • Remove the 9 screws on the plastic cover.
    • The Orange circle is the screw that holds the bracket in place . this screw does have a bushing on it DO NOT LOSE IT.
    • Cut zip tie on cable bundle .
  2. Presidential Footrest Disassembly, Step 2: stap 2, afbeelding 1 van 1
    • Tilt Footrest forward and remove 3 Bottom screws.
  3. Presidential Footrest Disassembly, Step 3: stap 3, afbeelding 1 van 1
    • Remove screws on left and right wheel and remove wheels from assembly .
    • Be sure to put wheels in safe place to avoid any damage.
  4. Presidential Footrest Disassembly, Complete: stap 4, afbeelding 1 van 1
    • WHEN PULLING OFF THE COVER THE CABLE BUNDLE WILL NEED TO BE THREADED THROUGH THE CUT OUT ON THE COVER. DO NOT FORCE IT. THIS MAY RESULT IN DAMAGING THE CONNECTORS .
    • You're done ! from here you have complete access to extend mechanism and valve.
Conclusie
To reassemble your device, follow these instructions in reverse order. DON'T FORGET TO REPLACE ANY CUT ZIP TIES
Nick
2.764 Reputatie
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 34
