Inleiding
Prying the exterior housing takes some force but is not difficult. If you are replacing the speaker unit, pry off the upper half.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Bijna klaar!
To reassemble your device, apply double-sided tape or adhesive on the existing glue and fit the housing back on.
Conclusie
