Ga door naar hoofdinhoud
Prerequisite Exterior Housing Disassembly
Wat je nodig hebt
  1. Prerequisite Exterior Housing Disassembly, Exterior Housing: stap 1, afbeelding 1 van 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: stap 1, afbeelding 2 van 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iOpener
    $24.99
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
Conclusie
To reassemble your device, apply double-sided tape or adhesive on the existing glue and fit the housing back on.
Jerrell
730 Reputatie
7 handleidingen geschreven
Cal Poly, Team 11-50, Amido Spring 2014 Lid van Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 405
