Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Gereedschap gebruikt in deze stap:iOpener$19.99-
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Peel away the black tape covering the red wires that connect to the PCB.
Slowly lift the PCB away from the rest of the device
Remove the ribbon by first removing the brown insert piece from the connector on the button board
Pull the ribbon out of the connector on the button board by the blue tab.
Carefully disconnect the white 11-pin connector from the main board.
Één andere persoon heeft deze handleiding voltooid.
