Ga door naar hoofdinhoud
PowerShot G7 X Mark II LCD Screen Replacement
Wat je nodig hebt
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
    Vraag FixBot
  2. PowerShot G7 X Mark II LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
    Vraag FixBot
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: stap 3, afbeelding 1 van 1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
    Vraag FixBot
  4. PowerShot G7 X Mark II LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • The screen is detached and can now be replaced.
    Vraag FixBot
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brandon
644 Reputatie
4 handleidingen geschreven
USF Tampa, Team 12-3, Eyestone Spring 2017 Lid van USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Leden
5Gids Commentaar
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Antwoord Deel
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Antwoord Deel
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali - Antwoord Deel
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Antwoord Deel
on ebay or amazon. you can order it
nicole - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 175
Altijd: 11,931
