Ga door naar hoofdinhoud
PowerLead Puto PLD003 Zoom Button Replacement
Wat je nodig hebt
  1. PowerLead Puto PLD003 Zoom Button Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Zoom Button Replacement: stap 2, afbeelding 1 van 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Zoom Button Replacement: stap 3, afbeelding 1 van 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Zoom Button Replacement: stap 4, afbeelding 1 van 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: stap 5, afbeelding 1 van 2 PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: stap 5, afbeelding 2 van 2
    • Remove the 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Zoom Button Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Zoom Button Replacement: stap 7, afbeelding 1 van 1
    • Apply pressure to the back panel, pulling away from the camera to remove it.
  8. PowerLead Puto PLD003 Zoom Button Replacement: stap 8, afbeelding 1 van 2 PowerLead Puto PLD003 Zoom Button Replacement: stap 8, afbeelding 2 van 2
    • Remove the final 4 mm Phillips #1 screw holding the screen in place.
    • This screw is very small and hard to see.
  9. PowerLead Puto PLD003 Zoom Button Replacement: stap 9, afbeelding 1 van 1
    • Carefully apply pressure away from the camera to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the zoom button easier.
  10. PowerLead Puto PLD003 Zoom Button Replacement: stap 10, afbeelding 1 van 1
    • Remove the three 4 mm Phillips #1 screws holding the top panel in place.
  11. PowerLead Puto PLD003 Zoom Button Replacement: stap 11, afbeelding 1 van 2 PowerLead Puto PLD003 Zoom Button Replacement: stap 11, afbeelding 2 van 2
    • Push upward on the top panel to remove it from the body of the camera.
  12. PowerLead Puto PLD003 Zoom Button Replacement: stap 12, afbeelding 1 van 2 PowerLead Puto PLD003 Zoom Button Replacement: stap 12, afbeelding 2 van 2
    • Remove the two 4 mm Phillips #1 screws holding the circuit board in place.
    • Do not remove the silver screws.
  13. PowerLead Puto PLD003 Zoom Button Replacement: stap 13, afbeelding 1 van 1
    • Lift the circuit board out of the plastic casing.
    • Gently pull on the zoom button to remove it from the circuit board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 170
