Inleiding
This guide shows how to remove the side panel from the camera, how to remove the back panel, and how to replace the lens.
Wat je nodig hebt
Remove the three 4 mm Phillips #1 screws holding the weight.
Remove the weight.
Carefully apply pressure, away from the camera, to the screen to detach it from the body.
The white cable should still be connected to the body.
OPTIONAL: Remove the screen to make accessing the lens easier
Bijna klaar!
Conclusie
