Ga door naar hoofdinhoud
PowerLead Puto PLD003 Back Buttons Replacement
Wat je nodig hebt
  1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Back Buttons Replacement: stap 2, afbeelding 1 van 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Back Buttons Replacement: stap 3, afbeelding 1 van 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Back Buttons Replacement: stap 4, afbeelding 1 van 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: stap 5, afbeelding 1 van 2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: stap 5, afbeelding 2 van 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Back Buttons Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Back Buttons Replacement: stap 7, afbeelding 1 van 1
    • Apply pressure to the back panel, away from the camera to remove.
  8. PowerLead Puto PLD003 Back Buttons Replacement: stap 8, afbeelding 1 van 2 PowerLead Puto PLD003 Back Buttons Replacement: stap 8, afbeelding 2 van 2
    • Place the back panel so the buttons are facing down and the circuit board is facing up.
    • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
  9. PowerLead Puto PLD003 Back Buttons Replacement: stap 9, afbeelding 1 van 1
    • Set aside the circuit board.
    • These nubs are what is currently holding the buttons in place.
    • Carefully apply pressure and remove the set of buttons from the nubs.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 261
