Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Changing the top case will also give you a new trackpad, but requires removing everything from the computer.
Wat je nodig hebt
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
Pull the RAM chip out.
Repeat this process if a second RAM chip is installed.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
Turn the G4 over.
Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the trackpad will lie flat on the work surface.
Remove the four T8 Torx screws that fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
