Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
19 andere personen hebben deze handleiding voltooid.
