Ga door naar hoofdinhoud
PowerBook G4 Titanium DVI Airport Card Replacement
Wat je nodig hebt
  1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: stap 1, afbeelding 1 van 2 PowerBook G4 Titanium DVI Airport Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: stap 2, afbeelding 1 van 2 PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: stap 2, afbeelding 2 van 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Airport Card Replacement, Airport Card: stap 3, afbeelding 1 van 1
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
Conclusie
19 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 22,384
