Ga door naar hoofdinhoud
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: stap 1, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Memory Door: stap 2, afbeelding 1 van 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: stap 3, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: stap 3, afbeelding 2 van 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: stap 4, afbeelding 1 van 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: stap 4, afbeelding 2 van 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: stap 4, afbeelding 3 van 3
    • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
    • Pull the RAM chip away from its socket and remove it from the logic board.
    • Repeat this process for the other RAM chip, if present.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
Één opmerking
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 8,363
