Inleiding
Remove your memory door to access the RAM chips.
Gereedschap
Onderdelen
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Één andere persoon heeft deze handleiding voltooid.
