Ga door naar hoofdinhoud
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement, Battery: stap 1, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement, Memory Door: stap 2, afbeelding 1 van 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 3, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 3, afbeelding 2 van 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement, DC-In Board: stap 4, afbeelding 1 van 1
    • Remove the strip of tape covering the speaker cables.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the RJ-11 cable from the modem.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 6, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 6, afbeelding 2 van 2
    • Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket.
    • The ZIF cable lock will move about 1 mm and stop. Do not attempt to completely remove the ZIF cable lock.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 7, afbeelding 1 van 1
    • Pull the DC-in cable out of its socket.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 8, afbeelding 1 van 1
    • Peel the DC-in cable off the adhesive securing it to the lower case.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 9, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 9, afbeelding 2 van 2
    • Use the tip of a spudger to remove the piece of foam tape from the channel on the side of the left speaker.
    • De-route the cables from the channel in the left speaker.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 10, afbeelding 1 van 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 10, afbeelding 2 van 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 10, afbeelding 3 van 3
    • Remove the single T8 Torx screw securing the left speaker to the lower case.
    • Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker.
    • Set the speaker next to the lower case.
  11. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 11, afbeelding 1 van 1
    • Pull the DC power cable connector straight up off the DC-in board.
  12. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the two T8 Torx screws securing the DC-in board to the lower case.
    • New line.
  13. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 13, afbeelding 1 van 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 13, afbeelding 2 van 2
    • Pull the DC-in board away from the side of the lower case to separate the ports from their bezel.
    • Lift the DC-in board out of the lower case.
  14. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement, RJ-11 Board: stap 14, afbeelding 1 van 1
    • Use your thumbs to slide the RJ-11 board slightly away from the DC-In board.
  15. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RJ-11 Board Replacement: stap 15, afbeelding 1 van 1
    • Use the flat end of a spudger to continue removing the RJ-11 board away from the DC-In board.
Conclusie
Bijgevoegde documenten
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 2,037
