Inleiding
All you need to remove the battery is your fingers!
Wat je nodig hebt
Orient the computer so that the side with the line of screws on it is away from you.
Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
Lift the battery out of the computer.
4 andere personen hebben deze handleiding voltooid.
Which screw driver I have to use here?
smartvideocanada - Antwoord
Phillips #00 Screwdriver: All necessary tools are available to buy at the top of this page if they are needed.
Sam Love -
