Ga door naar hoofdinhoud
PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement, Upper Case: stap 2, afbeelding 1 van 1
    • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
  3. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 3, afbeelding 1 van 1
    • Remove the memory compartment cover.
    • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
  4. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 4, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise so the power receptacle faces you.
    • Remove the three 3 mm Phillips screws along the edge of the lower case.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
  5. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 5, afbeelding 1 van 1
    • Turn the computer 90 degrees clockwise so the hinge faces you.
    • Remove the lower 5 mm Phillips screw on each side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 6, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise so the ports face you.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
  7. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 7, afbeelding 1 van 1
    • Turn the computer over and open the display.
    • Remove the two 4.2 mm long, 1.5 mm hex screws at the top corners of the upper case (two total).
    • A T6 Torx driver will work, but repeated use will strip the screws.
  8. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 8, afbeelding 1 van 1
    • Grasp the back corners of the upper case and pull up.
    • Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 9, afbeelding 1 van 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 10, afbeelding 1 van 1
    • Remove the amber tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board by pulling up on the connector.
    • Remove the upper case from the computer.
  11. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement, Battery Connector: stap 11, afbeelding 1 van 1
    • Remove the two Phillips screws securing the battery connector.
  12. PowerBook G4 Aluminum 15" 1.67 GHz Battery Connector Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the battery connector from the logic board.
Conclusie
Bijgevoegde documenten
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 8,399
