Ga door naar hoofdinhoud
PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, Upper Case: stap 2, afbeelding 1 van 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 3, afbeelding 1 van 1
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 4, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 5, afbeelding 1 van 1
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 6, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 7, afbeelding 1 van 1
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 8, afbeelding 1 van 1
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 9, afbeelding 1 van 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 10, afbeelding 1 van 1
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, Right Ambient Light Sensor: stap 11, afbeelding 1 van 1
    • Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
    • Remove the small 3 mm black Phillips screw from the bottom of the board.
  12. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 12, afbeelding 1 van 1
    • Lift the right ambient light sensor board Straight up from the Logic Board.
  13. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, Logic Board: stap 13, afbeelding 1 van 1
    • Remove the two black Phillips screws from the right speaker.
    • Lift the speaker away from the logic board and place it aside
  14. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 14, afbeelding 1 van 1
    • Use your fingernail to flip up the black plastic flap locking the modem cable in place.
    • Slide the modem cable from its connector.
  15. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the 13 indicated cables, removing tape as necessary.
    • When re-installing the board, make sure the two small connectors at the right hand side are above the board before inserting the screws.
  16. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 16, afbeelding 1 van 1
    • Remove the following 8 Phillips screws from the logic board:
    • Three 6.5 mm in the upper left corner.
    • Five 4.5 mm around the edges.
  17. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 17, afbeelding 1 van 1
    • Two cables still connect to the logic board and must be removed before pulling the board entirely out of the computer.
    • Use a spudger to gently (very gently) pry up the left side of the logic board.
    • If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
  18. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 18, afbeelding 1 van 1
    • Disconnect the DC-In connector from the left side of the logic board.
  19. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 19, afbeelding 1 van 1
    • Disconnect the battery cable from the front, left corner of the logic board.
  20. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 20, afbeelding 1 van 1
    • Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
    • Once the logic board clears the ports, slide it out to the left.
  21. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 21, afbeelding 1 van 1
    • Important: when you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage.
    • To properly reassemble your PowerBook, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  22. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 22, afbeelding 1 van 1
    • Use a firm plastic edge to scrape the thermal material off the processor.
    • When replacing the logic board, make sure all cables are routed around and above - not under - it, and to connect the two cables that do go beneath before pushing the board into place.
    • Place the logic board back in the computer, trying not to move it around once the processor has come into contact with the newly-applied thermal paste.
  23. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, Speakers: stap 23, afbeelding 1 van 1
    • Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
    • Lift the left ambient light sensor board out of the computer, removing tape as necessary.
  24. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 24, afbeelding 1 van 1
    • Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
  25. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 25, afbeelding 1 van 1
    • Disconnect the speaker cable from the DC/Sound card.
  26. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 26, afbeelding 1 van 1
    • Remove the 4 mm hex nut from below the left speaker.
    • Remove the 3 mm black Phillips screw from bottom left corner of the speaker assembly, to the left of the battery compartment.
  27. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 27, afbeelding 1 van 1
    • Lift the speaker assembly (including the right speaker) out of the computer.
  28. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement, PC Card Cage: stap 28, afbeelding 1 van 1
    • Remove the two 4.2 mm silver Phillips screws from the left corners of the PC card cage.
    • Next the two 6.8 mm shouldered screws go on the right side of the card cage.
  29. PowerBook G4 Aluminum 15" 1.5-1.67 GHz PC Card Cage Replacement: stap 29, afbeelding 1 van 1
    • Lift the PC card cage up and remove it from the computer.
    • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
Conclusie
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,414
