Ga door naar hoofdinhoud
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement, Upper Case: stap 2, afbeelding 1 van 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 3, afbeelding 1 van 1
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 4, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 5, afbeelding 1 van 1
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 6, afbeelding 1 van 1
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 7, afbeelding 1 van 1
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 8, afbeelding 1 van 1
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 9, afbeelding 1 van 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 10, afbeelding 1 van 1
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement, Hard Drive: stap 11, afbeelding 1 van 1
    • Remove the three long silver Phillips screws from the retaining bracket on the left side of the optical drive.
    • Remove the retaining bracket.
  12. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
  13. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 13, afbeelding 1 van 1
    • Lift the hard drive up from the right side and remove it from the computer.
  14. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement, Modem: stap 14, afbeelding 1 van 1
    • Remove the two silver Phillips screws from the modem board.
    • The screw in the top left corner has a black washer.
  15. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 15, afbeelding 1 van 1
    • Disconnect the large orange ribbon cable from the top of the modem.
  16. PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem Replacement: stap 16, afbeelding 1 van 1
    • Lift the modem up and disconnect the remaining cable, at which point the modem will be free.
Conclusie
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 2,881
