Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Open the computer and rotate the display as far as possible.
Remove the T6 Torx screw from the bottom left corner of the display assembly. The computer casing will not allow the screwdriver to be inserted directly into the screw, so be careful not to strip the screw.
Remove the T6 Torx screw from the bottom right corner of the display assembly.
Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Close the display.
Lift the bottom edge of the rear display bezel up about an inch.
Slide the rear display bezel forward to release the clips along the top edge of the display.
Rotate the rear display bezel away from the display and lay it next to the computer.
Remove the Phillips screw securing the inverter board.
Insert the pointed end of the a spudger between the protective tape and the inverter board.
Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
Disconnect the cable by pulling the connector away from the inverter board's socket.
Remove the two Phillips screws from both sides of the display (four in total).
Remove any tape on the display data cable.
Pull the display data cable connector away from its socket to disconnect it from the LCD.
Open the display slightly.
Push the LCD away from the front display bezel near its top edge.
Remove the LCD, being wary of any cables that may get caught
4 andere personen hebben deze handleiding voltooid.
