Ga door naar hoofdinhoud
PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement
Wat je nodig hebt
  1. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
    What can I say?
    It is certainly do able. I just completed it. Took me 2 hours. The most important tool you'll need is patience - bag full of patience!!
    Gopal - Antwoord
    Took 3 1/2 to 4 hours for someone who is handy but has never opened a computer before. Not so bad and it was a fun learning experience.
    Nomad Toes - Antwoord
    Citaat van Nomad Toes:
    Weird. I posted this on Step 1 of replacing the optical drive, but it showed up on the RAM page since Step 1 is the same. Replacing the RAM takes 10 minutes.
    I also see this on “replacing the battery” :-)
    atarixle -
    I guess, the hardest thing is to find a trustfully shop to buy a new one. You should create a manual how to disassemle the body of the battery and replace the standard round cells inside it.
    atarixle - Antwoord
  2. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, RAM: stap 2, afbeelding 1 van 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement: stap 3, afbeelding 1 van 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
Conclusie
40 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
Één opmerking
Why does my computer only show 768mb RAM after the upgrade? 1 RAM slot is the soldered 256mb and the other is 1gb.... Hm...
iamkiyoshi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 20,084
