Inleiding
One RAM slots allow up to 1.25 GB of PC2700 RAM.
Wat je nodig hebt
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
40 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
Één opmerking
Why does my computer only show 768mb RAM after the upgrade? 1 RAM slot is the soldered 256mb and the other is 1gb.... Hm...
What can I say?
It is certainly do able. I just completed it. Took me 2 hours. The most important tool you'll need is patience - bag full of patience!!
Gopal - Antwoord
Took 3 1/2 to 4 hours for someone who is handy but has never opened a computer before. Not so bad and it was a fun learning experience.
Nomad Toes - Antwoord
Weird. I posted this on Step 1 of replacing the optical drive, but it showed up on the RAM page since Step 1 is the same. Replacing the RAM takes 10 minutes.
I also see this on “replacing the battery” :-)
atarixle -
I guess, the hardest thing is to find a trustfully shop to buy a new one. You should create a manual how to disassemle the body of the battery and replace the standard round cells inside it.
atarixle - Antwoord
