Inleiding
Two RAM slots allow up to 512 MB of PC100 RAM.
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. There is a similar RAM slot located on the other side of the processor.
11 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
Één commentaar
Thanks for this guide! One comment : you don’t really need to disconnect the keyboard (steps 4 and 5), you just need to be careful not to damage the keyboard connectors when taking in and out the hard disk and Ram. I think there is more chance that you damage the keyboard connectors by pulling them out.
