Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
Rest the keyboard on the trackpad.
1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
2) After disengaging the locking bar, slide the cable out of the connector.
Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
Once the strain relief cables are free, lift the keyboard off.
Remove the two Phillips screws from the heat shield.
Grasp the metal handle on the heat shield and pull up and toward yourself.
Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
Grasp the hard drive bracket on the left side and pull up and to the left.
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
Remove the single Phillips screw from the modem.
Disconnect the orange PMU cable by pulling it directly up.
Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
Remove the modem by sliding it up and to the right.
Push the display back so that it lies flat.
Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
Repeat the previous step on the left side.
Lift the clutch cover off by rotating it up and then toward you.
15 andere personen hebben deze handleiding voltooid.
