Ga door naar hoofdinhoud
PowerBook G3 Lombard Power Card Replacement
Wat je nodig hebt
  1. PowerBook G3 Lombard Power Card Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Power Card Replacement: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Power Card Replacement: stap 3, afbeelding 1 van 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Power Card Replacement, Heat Shield: stap 4, afbeelding 1 van 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Power Card Replacement: stap 5, afbeelding 1 van 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Power Card Replacement: stap 6, afbeelding 1 van 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Power Card Replacement, PRAM Battery: stap 7, afbeelding 1 van 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Power Card Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Power Card Replacement, Modem: stap 9, afbeelding 1 van 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Power Card Replacement: stap 10, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Power Card Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Power Card Replacement: stap 12, afbeelding 1 van 1
  13. PowerBook G3 Lombard Power Card Replacement, Processor: stap 13, afbeelding 1 van 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Power Card Replacement: stap 14, afbeelding 1 van 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Power Card Replacement: stap 15, afbeelding 1 van 1
  16. PowerBook G3 Lombard Power Card Replacement, RAM: stap 16, afbeelding 1 van 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
  17. PowerBook G3 Lombard Power Card Replacement, Hard Drive: stap 17, afbeelding 1 van 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  18. PowerBook G3 Lombard Power Card Replacement: stap 18, afbeelding 1 van 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
  19. PowerBook G3 Lombard Power Card Replacement, Clutch Cover: stap 19, afbeelding 1 van 1
    • Push the display back so that it lies flat.
  20. PowerBook G3 Lombard Power Card Replacement: stap 20, afbeelding 1 van 1
    • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
  21. PowerBook G3 Lombard Power Card Replacement: stap 21, afbeelding 1 van 1
    • Lift the clutch cover up and off, rotating it toward yourself.
  22. PowerBook G3 Lombard Power Card Replacement, Inverter: stap 22, afbeelding 1 van 1
    • Grasp the orange display data cable and disconnect it from the logic board.
    • Pull the display cable straight up so that it is vertical.
  23. PowerBook G3 Lombard Power Card Replacement: stap 23, afbeelding 1 van 1
    • Grasp the thin display inverter board at its left end, push the left end forward to get the board beyond the tab, and then lift the entire board up.
    • There are two tabs that hold the display inverter in place that you need to get past in order to pull the board free.
  24. PowerBook G3 Lombard Power Card Replacement: stap 24, afbeelding 1 van 1
    • Disconnect the white inverter cable connector from the right end of the board.
  25. PowerBook G3 Lombard Power Card Replacement: stap 25, afbeelding 1 van 1
    • Disconnect the inverter plug, pulling directly up from the logic board.
  26. PowerBook G3 Lombard Power Card Replacement: stap 26, afbeelding 1 van 1
  27. PowerBook G3 Lombard Power Card Replacement, Display: stap 27, afbeelding 1 van 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
  28. PowerBook G3 Lombard Power Card Replacement: stap 28, afbeelding 1 van 1
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
  29. PowerBook G3 Lombard Power Card Replacement: stap 29, afbeelding 1 van 1
  30. PowerBook G3 Lombard Power Card Replacement, Upper Case: stap 30, afbeelding 1 van 1
    • Remove the three long silver and two short black Torx screws from the beige plastic casing.
  31. PowerBook G3 Lombard Power Card Replacement: stap 31, afbeelding 1 van 1
    • Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
    • Disconnect the newly revealed thin orange ribbon from the logic board, to the left of the trackpad.
    • Remove the two long silver Torx screws.
    • Turn the laptop over.
    • Remove the seven Torx screws from the bottom casing.
    • There are two long screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
    • Turn the laptop back over.
    • Remove the three short black Torx screws from the metal frame.
    • Remove the short black Torx screw to the far left that fastens the logic board to the casing.
    • There is a small black plastic spacer that goes between the bottom left screw and the logic board.
  32. PowerBook G3 Lombard Power Card Replacement: stap 34, afbeelding 1 van 1
    • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
  33. PowerBook G3 Lombard Power Card Replacement: stap 35, afbeelding 1 van 1
    • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
  34. PowerBook G3 Lombard Power Card Replacement: stap 36, afbeelding 1 van 1
    • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
  35. PowerBook G3 Lombard Power Card Replacement: stap 37, afbeelding 1 van 1
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  36. PowerBook G3 Lombard Power Card Replacement: stap 38, afbeelding 1 van 1
  37. PowerBook G3 Lombard Power Card Replacement, Power Card: stap 39, afbeelding 1 van 1
    • Remove the two long silver Torx screws from the power card in the center of the laptop.
    • Grasp the power card near the black plastic shield and lift up.
Conclusie
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 5,878
