Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If your keyboard is malfunctioning you can remove the keyboard to clean it. If that doesn't solve your problem you will need to replace the keyboard.
Wat je nodig hebt
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
