Inleiding
If your hard drive was damaged or you want to upgrade it you will need to remove the old hard drive first. However, the hard drive is one of the hardest components to reach. Make sure you are able to keep all removed parts organized to make your reassembly process easier.
Onderdelen
Geen onderdelen nodig.
  1. Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
    • Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
  2. Press and hold the button on the left of the front side, and slide the battery out.
    • Press and hold the button on the left of the front side, and slide the battery out.
    • With a T8 torx screwdriver, remove the three 24mm torx screws along the middle of the back panel.
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
    • Then carefully lift the top half of the keyboard, and rotate it towards yourself.
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
    • Disconnect the wires from the port.
    • Remove the 7mm screw connecting the speaker panel to the computer.
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
    • Push the display screen back to give yourself enough space to remove the side panels.
    • Before removing the side panels, note that removing the side panels hastily will damage the underlying panel screw. However, this will not affect the functionality of your PowerBook.
    • Remove the panels on either side by gently but firmly pulling up on them with both hands.
    • Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
    • WARNING: There is a high risk of breaking the tabs that lock the panel to the casing. Remove the panel slowly and cautiously to avoid damage.
    • With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
    • Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
    • A ribbon cable is attached to the underside of the hard drive. Hasty removal of the hard drive can damage the ribbon cable.
    • Gently lift up on the hard drive.
    • Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable.
    • You might find it easier to set the hard drive on its side while disconnect the ribbon cable.
    • Place the hard drive so that the casing is facing up.
    • Remove the 4 T8 5mm long torx screws to remove the hard drive from the metal casing.
    • Lift the metal casing off of the hard drive.
    • Remove and set aside the black protector that was under the hard drive casing.
    • If your replacement drive did not come with a ribbon cable, use a plastic opening tool to remove the ribbon cable from your old hard drive.
    • Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free.
    • When you have loosened the connection, pull the tab to remove the ribbon cable.
Conclusie
Install the new hard drive by following these instructions in reverse order.
Michael Mondragon
115 Reputatie
9 handleidingen geschreven
Cal Poly, Team 24-59, Amido Spring 2011 Lid van Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Leden
Thanks for the great guide! I used this guide on my Original PowerBook G3 (Kanga / 3500). Thank you!
Stephen - Antwoord
Looks like a excellent guide. I have a Kanga waiting and now I will make a plan
dscpinc - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 37
Altijd: 3,987
