Inleiding
If your display is broken or damaged you will need to replace the entire display.
Wat je nodig hebt
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
Gently remove the ribbons from its tabs.
I did find that, strictly speaking, you don’t need to remove the ribbons. If you carefully hold up the keyboard up towards the screen with one hand, you can remove the old RAM and install the new one with the other. I suppose you could also use a length of masking tape to hold the keyboard up.
I found it easier not to remove the ribbon, especially as I couldn’t find my plastic opening tool.
Disconnect the wires from the port.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
To replace the display, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Note that the side panels should be placed back BEFORE the audio panel.
