Inleiding
If your display is broken or damaged you will need to replace the entire display.
Wat je nodig hebt
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
To replace the display, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Note that the side panels should be placed back BEFORE the audio panel.
