Ga door naar hoofdinhoud
PowerBook 180 Modem Replacement
Wat je nodig hebt
  1. PowerBook 180 Modem Replacement, Modem: stap 1, afbeelding 1 van 2 PowerBook 180 Modem Replacement, Modem: stap 1, afbeelding 2 van 2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: stap 2, afbeelding 1 van 2 PowerBook 180 Modem Replacement: stap 2, afbeelding 2 van 2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: stap 3, afbeelding 1 van 2 PowerBook 180 Modem Replacement: stap 3, afbeelding 2 van 2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: stap 4, afbeelding 1 van 2 PowerBook 180 Modem Replacement: stap 4, afbeelding 2 van 2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jack Byrnes
1.244 Reputatie
2 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
Één opmerking
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,612
