Ga door naar hoofdinhoud
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Wat je nodig hebt
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: stap 1, afbeelding 1 van 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: stap 1, afbeelding 2 van 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: stap 2, afbeelding 1 van 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: stap 3, afbeelding 1 van 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: stap 3, afbeelding 2 van 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: stap 3, afbeelding 3 van 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: stap 4, afbeelding 1 van 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Faizan Naveed
3.294 Reputatie
8 handleidingen geschreven
Mobile Device Repair Factory Lid van Mobile Device Repair Factory
Business
1 Lid
16 handleidingen geschreven
5 opmerkingen
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Antwoord
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Antwoord
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Antwoord
My bettry is too good work but tha wireis want to b change
Asoo Malik - Antwoord
Plzz tel me how I can change tha wire of my power beats
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 100
Altijd: 29,124
