Ga door naar hoofdinhoud
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
Wat je nodig hebt
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: stap 1, afbeelding 1 van 1
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: stap 2, afbeelding 1 van 1
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: stap 3, afbeelding 1 van 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: stap 3, afbeelding 2 van 2
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: stap 4, afbeelding 1 van 1
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: stap 5, afbeelding 1 van 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: stap 5, afbeelding 2 van 2
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Faizan Naveed
3.294 Reputatie
8 handleidingen geschreven
Mobile Device Repair Factory Lid van Mobile Device Repair Factory
Business
1 Lid
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 61
Altijd: 26,989
