Ga door naar hoofdinhoud
PowerA Spectra Infinity Enhanced Vibration Motors Replacement
Wat je nodig hebt
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: stap 1, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 3, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 3, afbeelding 2 van 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 5, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 5, afbeelding 2 van 2
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: stap 6, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: stap 6, afbeelding 2 van 2
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 7, afbeelding 1 van 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 7, afbeelding 2 van 2
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 8, afbeelding 1 van 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 8, afbeelding 2 van 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: stap 8, afbeelding 3 van 3
    • Remove the completely freed vibration motor from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevyn Jorge
955 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 6-5, Botvin Spring 2024 Lid van UMass Dartmouth, Team 6-5, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 65
