Ga door naar hoofdinhoud
PowerA Fusion Controller For Xbox One Motherboard Replacement
Wat je nodig hebt
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: stap 1, afbeelding 1 van 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: stap 1, afbeelding 2 van 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: stap 1, afbeelding 3 van 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 2, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 3, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 5, afbeelding 1 van 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrea
623 Reputatie
4 handleidingen geschreven
USF Tampa, Team S14-G4, Boczar Fall 2017 Lid van USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Leden
5 handleidingen geschreven
Één opmerking
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 2,898
