Ga door naar hoofdinhoud
PowerA Enhanced Wireless Controller L and R Thumbstick Replacement
Wat je nodig hebt
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: stap 1, afbeelding 1 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: stap 1, afbeelding 2 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 3, afbeelding 1 van 2 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 3, afbeelding 2 van 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 4, afbeelding 1 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 4, afbeelding 2 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement: stap 4, afbeelding 3 van 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: stap 5, afbeelding 1 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: stap 5, afbeelding 2 van 3 PowerA Enhanced Wireless Controller L and R Thumbstick Replacement, L and R Thumbsticks: stap 5, afbeelding 3 van 3
    • Pull the L and R sticks out of the socket.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Ayjah Montgomery
402 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G5, Leahy Fall 2019 Lid van USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Leden
10 handleidingen geschreven
19 opmerkingen
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - Antwoord
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - Antwoord
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 190
Altijd: 13,297
