Ga door naar hoofdinhoud
PowerA Enhanced Wireless Controller Directional Pad Replacement
Wat je nodig hebt
  1. PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: stap 1, afbeelding 1 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: stap 1, afbeelding 2 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 3, afbeelding 1 van 2 PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 3, afbeelding 2 van 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 4, afbeelding 1 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 4, afbeelding 2 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement: stap 4, afbeelding 3 van 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: stap 5, afbeelding 1 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: stap 5, afbeelding 2 van 3 PowerA Enhanced Wireless Controller Directional Pad Replacement, Directional Pad: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use the rubber tweezers to grab the center of the directional pad and pull it out by pinching its center.
Conclusie
Ayjah Montgomery
420 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G5, Leahy Fall 2019 Lid van USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 39
Altijd: 1,407
